Rupture Disc Bursting At Reactantant Accumulation Scenario At Exotherm
pressure buildup
#1 saravananchem
saravananchem
  • 6 posts
Posted 28 December 2017 - 11:18 PM
I have a problem.
Reactor is 3 KL
Reaction between A and B in solvent S
A and solvent are in the reactor filled with 50% of the reactor volume.
Heat of rxn is x cal/kg
3 kl reactor have 1.5 kl empty space. reaction at solvent S boiling temp.
no heat removal by jacket. scenario : condenser cooling failure.
Reactor design pr is 6 kg/cm2. and Rupture disc design pressure 2 kg/cm2
Problem: when cooling failure, how many kg of B is required to burst the rupture disc.
How to do this problem.
Ideal gas law we need to use.
#2 latexman
  • 1,820 posts
Posted 29 December 2017 - 07:52 AM
Assume adiabatic.  Numerically (spreadsheet) initiate and progress the reaction with material and energy balance until mixture total pressure = RD burst pressure.
#3 breizh
  • 6,747 posts
Posted 29 December 2017 - 08:58 AM
hi ,
To support your work , in addition to Latexman's reply , let you get a copy of :
 "Chemical process safety , fundamentals with applications 3rd edition " by Daniel A Crowl and Joseph F Louvar .
Hope this is going to help you .
#4 saravananchem
saravananchem
  • 6 posts
Posted 29 December 2017 - 09:25 AM
Thanks.
Mean I need calculate the pressure inside the vessel by heat generate from the exothermic reaction and the solvent is being boiled up.
with available empty space and caudate the p by ideal gas law?
am I correct?
#5 breizh
  • 6,747 posts
Posted 29 December 2017 - 07:09 PM
Hello ,
To add to my previous email , consider reading the document attached . To me you are going to release a 2 phases mixture through the RD .
Hope this is helping you .
Breizh .
#6 saravananchem
saravananchem
  • 6 posts
Posted 29 December 2017 - 10:19 PM
Thanks a lot.
