hi
ı am working on a master these about solar organic rankine cycle
ı am using aspen plus software.
when ı model a simulation, there is an error in the heat exchanger
ERROR
OUTLET FLASH FAILED TO CONVERGE.
ERROR
FLASH CALCULATION HAS DRIVEN THE TEMPERATURE DOWN TO THE LOWER LIMIT OF
120.0000 DEGREES K., BUT ENTHALPY BALANCE IS STILL NOT SATISFIED. HEAT
DUTY SPECIFICATIONS MAY BE INFEASIBLE. ERROR IN FLASH CALCULATIONS FOR
FEED STREAM FLASH.
can you help me???????????*
