Can I Simulate A Turbocompressor In Hysys ?
#1 medelamine
medelamine
  • 22 posts
Posted 06 February 2018 - 10:33 AM
I wonder if I can simulate a turbo-compressor in Hysys ? for the compressor it's straightforward, however, for the turbine ? can I simply use the expander ?
#2 serra
serra
  • 311 posts
Posted 07 February 2018 - 02:14 AM
normally you get a package including both compressor and turbine,
manufacturers can provide the details with operating curves,
for preliminary estimates look for some generic value of efficiency (for turbines this varies depending from size),
if you have the operating curves of compressor (or turbine) you can use these,
many tools are available for thermodynamic simulation
(I have used Excel + Prode Properties library)
but specific applications (some adopt CFD codes) can be more accurate.
#3 Pilesar
  • 1,556 posts
Posted 07 February 2018 - 01:00 PM
Use the expander. This is the usual procedure. Configure it so that the compressor work is slightly less than the expander work.
#4 adza
adza
Posted 22 September 2018 - 03:06 AM
No you cannot
You need to build the whole model of the turbine
#5 jessetom
jessetom
Posted 24 February 2019 - 12:24 PM
I think you will need to define a compressor and expander in HYSYS then use the link in the connection tab to connect their shaft so that, since it is considered an isentropic process, the work of the expander is routed to the compressor through the linked shafts in HYSYS and your aim achieved. Hope this helps
