Dear all,
I am new in project engineering and would like to ask several things that a little bit confusing to me. Hopefully someone here can help me in understanding the differences in the following project stage:
BEDP (Basic Engineering Design Package)
I read in several discussion that BEDP is essensially FEED (Front End Engineering Design). Is that correct or is there any difference between BEDP and FEED? I discussed with my colleague, and he said that BEDP is the product of licensor (inside battery limit) and FEED is for the outside battery limit of the plant. Both have the same level of detail and can be used further for EPC tender purpose.
In case the plant is not a licensed plant (such as utility plant or tank terminal complex facility), is it correct to call it BEDP or should it be called FEED?
I also read an statement which states:
1. BEDP ISBL (inside battery limit) to be done by company X
2. BEDP OSBL (outside battery limit) to be done by company Y
3. FEED to be done by company Z
Does it mean that BEDP and FEED are different? If it is different, what are the differences?
Thank you in advance.
