Heat Exchanger Design
heat exchanger process temperature enthalpy process design help engineering chemical chemical engineering
#1 mcharles1
mcharles1
Posted 10 February 2018 - 09:26 AM
I'm having some trouble breaking down this project question:
"To design a total horizontal shell and tube condenser which condenses 2.5 kg/s of saturated toluene vapor at 4.5 barg to a saturated liquid using cooling water at 50°C and 2.5 barg with a maximum temperature increase of 20°C."
My questions are"
1. is the Tout temperature found at the boiling temperature of toluene? i.e. at a saturated liquid?
2. for the cooling water, is Tout 70degC? (50degC +20degC)
3. is Tin for toluene found antonie's equation?
4. If i am to construct a temperature-enthalpy diagram how can I do that with the information given? dont think I've ever seen a temperature-enthalpy diagram for toluene
please help
  • 6,942 posts
Posted 10 February 2018 - 11:43 AM
Here to support your work : a data base for toluene where you will find all the data needed to answer your questions .
note : point 4 : refer to heat of vaporization
https://www.cheric.o...p.php?cmpid=652
We are not doing your homework but we are happy to help.
Edited by breizh, 10 February 2018 - 11:55 AM.
