Turbo Compressor, Wet Gas Simulation
Posted 15 February 2018 - 11:50 AM
Posted 15 February 2018 - 12:23 PM
with wet gas (in my opinion) if you know (or can estimate, for example from absorbed power and mechanical efficiency) shaft horsepower better to (estimate) polytropic efficiency from that value,
with wet gas there could be a non-equilibrium condition at discharge, other possible errors (in temperatures) can result from heat transfer, condensate draining etc. etc.
the same for turbines (in turbo compressors),
unfortunately, as far as I know, there are no standards (as ASME PTC10) for wet gas,
the polytropic model with phase equilibria in Prode Properties is accurate (about the same accuracy of reference model in PTC10) but you must use it with care... (the same for other process simulators, of course)
see also similar threads at cheresources...
Edited by PaoloPemi, 15 February 2018 - 12:34 PM.
Posted 15 February 2018 - 12:58 PM
thanks Paolo,
I have found a paper from NTU discussing that solution (i.e. consider shaft horsepower in addition to discharge temperature),
it seems interesting.
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
Psv On Centrifugal Compressor DischargeStarted by Guest_Lyne_* , 10 Jun 2025 |
![]() Lng Boil Off Gas Compressor Suction DrumStarted by Guest_Lyne_* , 04 Jun 2025 |
Parallel Compressor Setup With Uneven CapacitiesStarted by Guest_sinrem_* , 13 May 2025 |
Aspen Hysys Simulation Of Acid Gas Removal UnitStarted by Guest_R.t_* , 22 May 2025 |
