Other Product From Hydrogen, Synthesis Gas Or Ammonia
Posted 05 April 2018 - 05:42 AM
I need to know-
1. How to utilize surplus ammonia to make other product to increase profitability.
2. Using Hydrogen gas generated equivalent to 100 MTPD ammonia and produce different product.
3. Using synthesis gas equivalent to 100 MTPD ammonia and produce different product.
I shall be ready to answer any queries to solve the problem.
Alok Jaiswal
Posted 07 April 2018 - 01:45 AM
Alok Jaiswal
Posted 08 April 2018 - 10:55 AM
Ammonia can be made into nitric acid and then ammonium nitrate, but usually this requires scale (much more than 100 t/d).
Synthesis gas can be made into just about anything, but the capital to do so may not be viable at small scale. Simplest first step would be to make methanol. From there you can make lots of other things.
Posted 09 April 2018 - 05:02 AM
What are the viable products which can be manufactured from Methanol.
We have synthesis gas as follws.
Quantity which can be spared: 10000 NM3/hr
Pressure: 25 kg/cm2g
Temperature: 10 - 40 Deg C
N2: 25 % (molar basis)
H2: 72 % (molar basis)
CH4+Ar: balance.
Alok Jaiswal
Posted 09 April 2018 - 09:17 AM
See here: http://www.essential...s/methanol.html
Starting from syngas you can make methanol, then formaldehyde, or methanal, or acetic acid. From there you can make many plastics and other fine chemicals.
Aspen Plus Conceptual Mof Synthesis Model: Elecnrtl, Ionic Leachate, PStarted by Guest_Momo_212_* , 16 Apr 2026 |
Thermodynamic Model For Methylamine SynthesisStarted by Guest_Ak_sxngh_* , 28 Nov 2025 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Benfield Solution For Ammonia PlantStarted by Guest_Chemist Ahmed_* , 03 Dec 2023 |
