Wet Scrubber Design For Low Flow Rate Of Gas
wet scrubber absorption nox design calculation
7 replies to this topic
#1 SIVAMOORTHY
SIVAMOORTHY
  • 41 posts
Posted 17 April 2018 - 08:06 AM
Hello everyone,
I have to design a wet scrubber for gas flow rate of 16 cubic meter per hour. Gas stream is having 5 % NOx.
Normally, we used to design wet scrubber for above 500 CFM. In these, we will keep superficial velocity in the absorption column as constant ( i.e. 200 to 400 fpm). Anyway, I have to check Flooding percent for this.
So, for this much low flow rate ( 16 cmh), if i keep 200 fpm of velocity, I am getting absorption column dia of 0.3 ft. It is 75 mm only.
I feel that column dia is very very less.
Is it correct by keeping 75 mm of dia.?
Is there any rule to keep minimum dia of absorption column?
Please discuss about this.
  • 6,939 posts
Posted 18 April 2018 - 05:14 AM
Consider these resources to support your work.
Edited by breizh, 18 April 2018 - 12:20 PM.
#3 SIVAMOORTHY
SIVAMOORTHY
  • 41 posts
Posted 18 April 2018 - 08:17 AM
Consider this resources to support your work.
Thank you sir..
#4 jknsd
jknsd
Posted 17 March 2023 - 07:40 PM
Hi Breizh. I have the same question, but can't see the resources you added. Please would you be able to share again? Thanks a lot
#5 breizh
  • 6,939 posts
Posted 18 March 2023 - 01:02 AM
To support your work
#6 csantander
csantander
  • 6 posts
Posted 29 August 2025 - 01:01 PM
Hi Breizh, Please would you be able to share again the document?
#7 breizh
  • 6,939 posts
Posted 29 August 2025 - 09:16 PM
A few documents
#8 csantander
csantander
  • 6 posts
Posted 01 September 2025 - 02:54 PM
Tnahk you!
