In HYSYS Spreadsheet, is there a possibility to easily use the "Import Variable"? I always right click and Import Variable, and then find the stream, then variable. I have a huge spreadsheet at the moment and importing them one by one will consume a lot of time.
Hysys Spreadsheet - Import Variable
Started by chocobang, Apr 19 2018 12:37 AM
