Blocked Discharge Case Psv Relief Rate
psv relief
#1 erwinfs
erwinfs
  • 12 posts
Posted 19 April 2018 - 11:16 PM
I want to size a PSV based on blocked discharge case. My protected equipment has 120 MMSCFD as maximum expected flowrate. The fluid is natural gas.
If I want to size this  PSV, should I set 120 MMSCFD as the relieving rate? Can I get reduced relieving rate?
Because API 521 state the following:
"Consideration can be given to the reduction of the relief rate as the result of the relieving pressure being above operating pressure."
And if so, how do I calculate the reduced relieving rate?
#2 Bobby Strain
Posted 19 April 2018 - 11:26 PM
When you look here for answers to questions such as this, that is not a good thing. You should seek advice within your organization for such situations.
#3 fallah
  • 5,026 posts
Posted 20 April 2018 - 12:18 AM
erwinfs,
If you apply mass flow rate you would have no concern about the pressure variation...
#4 latexman
  • 1,892 posts
Posted 20 April 2018 - 08:11 AM
It is common for compressor manufacturers to give flow capacity at several delivery pressures.
#5 Saml
Saml
  • 301 posts
Posted 22 April 2018 - 10:14 PM
You should consider the flow rate at 110% of MAWP or 116% MAWP if multiple valves are used.
i.e. if your equipment is downstream a centrifugal compressor you can expect a reduction in the relieving rate when the discharge pressure is higher. The compressor will not deliver as much flow at 110% pressure that it does at normal operating pressure.
#6 erwinfs
erwinfs
  • 12 posts
Posted 24 April 2018 - 01:07 AM
Thanks All, for the answers  :)
