We are working for a tolling manufacturer who has over 240 independent chemicals that can be added into their reactors. Is there a generalized chemical/properties we can use in lieu of evaluating all of them? Even if we did evaluate all of them, there are a near infinite number of combinations of chemicals since these chemicals are manually batched in by the operators (the plant does not have a DCS). How can we size these relief devices? The client recommended using heptane to evaluate the vapor scenario, but we cannot find a basis for that assumption anywhere in literature. Note: we are going to Fauske to evaluate reactive scenario relief rates. I have another idea how to handle this, but I want to get everybody's ideas first.
Generalized Chemical For Prd Sizing - Similar To Hexane For Atm Tanks
Posted 20 April 2018 - 08:45 AM
Posted 20 April 2018 - 09:36 AM
ryn376,
It might you get the properties of the heavier gas as a basis for sizing of all PSV's but then the sized PSV's for light gases might be over sized; and more importantly the run away reaction in the reactors might be credible and brings the products into play while they might not already be included in initial evaluation...
Posted 23 April 2018 - 08:24 AM
Yes, the difficulty is that there are so many chemicals that we will not be able to evaluate them all. We will make sure to use rupture discs to prevent any chattering that could occur for lower relieving rates. Even still the sizing procedure is unknown since we cannot find properties for all the chemicals. If there is no guidance on a generalized chemical to use in lieu or an actual one, we are sort of stuck...
Steam Drum SizingStarted by Guest_nastaran_* , 01 Dec 2025 |
Foam System Criteria For Hc Condensate Storage TanksStarted by Guest_Haideri_* , 28 Oct 2025 |
Sizing Of Condensate Return VesselsStarted by Guest_panoska_* , 23 Oct 2025 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
Sizing And And Process Control Of Filter PressStarted by Guest_Amalina Jamil_* , 11 Mar 2019 |
