Virtual Stream In Hysys
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 03 May 2018 - 09:13 AM
Can you tell me What is the use of virtual stream in hysys and how to use it ?  With virtual stream, I will be able to export composition , temp, pressure and flow from original stream , then I can use duplicate stream as well in hysys. why virtual stream is introduced?
#2 walidd_23
walidd_23
  • 27 posts
Posted 03 May 2018 - 12:38 PM
Hi
virtual stream can be used to export different data from the original stream (A) to another stream (B) , if the exported data on stream (A ) changed ,it will be changed on stream (B) as well. which is not the case if we use duplicate stream.
