There is an equation for estimating the boiling point of pure component at different pressure.
ln(P1/P2)=-Hevap/R X (1/T1-1/T2)
Since the enthalpy of vaporation is changing with pressure/temperature (boiling point), is the equation reliable?
Posted 07 May 2018 - 09:26 AM
Posted 07 May 2018 - 10:30 AM
I think a lot depends on what you mean by "reliable"?
A quick check based on water (using NIST's REFPROP for the reference calculations), it appears that your simplified equation (appears to be based on the Clausius-Clapeyron equation) is off by about 1 C at 0.25 atm and about 0.25 C at 3 atm. Is that "reliable"? For organics (tested on methanol, toluene, octane), the errors are larger (2-3 C at 0.25 atm and 1.5 to 2.5 C at 3 atm). I suggest that you perform similar calculations for test compounds that make sense to you, then determine exactly what "reliable" means in terms of those errors.
Heat Exchanger Steam FlowStarted by Guest_aliebrahem17_* , 25 Nov 2024 |
Discussion - Predict Storage Tank Heat Transfer Precisely By Jimmy D KStarted by Guest_raj shekhar_* , 25 Mar 2025 |
Cross Over Temperature In Countercurrent Heat ExchangerStarted by Guest_panoska_* , 18 Feb 2025 |
Aspen Hysys - Blowdown Utility Heat Flux MethodStarted by Guest_yuvi.ardekar1999@gmail.com_* , 27 Feb 2025 |
