We use MEA if pH value dr below 6.5 to raise pH, during this activity we observed that if we directly dose it to surge drum we see a temperature raise in surge drum of about 6-8 c and colour change - turns into brown and if not filtered properly it turns into slightly black.
If we shock dose the same slowly to lean glycol pump suction there is no temperature rise observed. Although color change is observed.
I understand that by addition of MEA iron is precipitating out and ineffective filtration leads to colour change but I don't get the temperature raise problem issue. Is that because MEA is highly reactive and which is the primary reason for the temp raise ??????
Would like to know what are the corrosion inhibitors options used in other plants, what are the problems they face post addition of corrosion inhibitors to the system and what is the procedure of addition ?? and some more insight to the problem which I stated above will be helpful for my understanding.
