I have configured detailed tray internals in steady state column/internals tab in Aspen hysys. but I am getting choke flood error for all trays that it exceeds 100 percent choke flood. In my process flows, I have exceeded the flow of reflux by 6 kg/hr to match top draw and bottom draw. due to this, I think this is happening., but how to eliminate that error without changing the top flows and reflux flows.
Distillation Column Internals
Started by CHEMSTRONG, May 13 2018 11:18 AM
Posted 13 May 2018 - 11:18 AM
Posted 13 May 2018 - 02:23 PM
I would obtain a solution without tray details. Then rate the trays with one of the vendor programs.
Posted 14 May 2018 - 08:09 AM
The tray design should be based on the vapor and liquid load.
Posted 10 June 2018 - 02:42 PM
Is the tray rating utility in HYSYS actually representative of your trays? My plant has a bespoke tray design that cannot be covered by these simple utilities. I utilize the Kister & Haas flooding correlations in a spreadsheet function in lieu.
