2 turbines run 5 compressors. I need to combine 2 energy streams and then split to 5 for simulation purposes. Is it possible in Aspen HYSYS ?
P.S: Of course, mix and tee does not work.
Posted 22 May 2018 - 12:12 AM
Posted 22 May 2018 - 03:22 AM
Elvin,
Spreadsheet can be used on this case, just attach the turbine duties to spreadsheet , the sum of duties divided by 5 , and link the result to the compressor duty , duplicate the same duty for other compressors.
Walid
