I've a query.
Please let me know what is the purpose of the U-seal/ loop given in the reflux line from Condenser to the Column/Reactor. (Reactor/Column and Condenser are under vacuum).
Rasik
U Loop/ Seal In Relfux Line
Started by rasik kirane, Sep 05 2006 03:09 AM
Posted 05 September 2006 - 03:09 AM
Posted 05 September 2006 - 06:59 AM
Rasik:
I think the attached sketch outlines what you are describing. It also explains why a liquid seal loop - a "P" trap - is employed.
Rasiks_Liquid_Seal.xls 17KB
531 downloads
Posted 26 May 2012 - 12:09 AM
sir
i want to know; why the u loop is provide in the reactor to scrubber (vaccum line) line venturi system?
Posted 26 May 2012 - 11:56 AM
Siddhav: It might help if you provide a sketch and a short explanation of what your question is, so that we can all try to help you. I await your reply.
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
Inlet Line Not Free DrainingStarted by Guest_Asifdcet_* , 07 Apr 2025 |
