Gas Dehydration With Teg
column convergence problem
#1 JABC
JABC
  • 3 posts
Posted 13 July 2018 - 05:16 AM
hi guys
I want to simulate a dehydration unit using glycol as absorber, I have defined the feed streams for absorber (TEG and Gas ) and the property package I chose is "Glycol package for all inlet and outlet streams". but there is a problem, the column does not recognize the fluid package I want to use "glycol" and by default it uses another defined fluid package "peng robinson"(which I made for other streams).even I cant change the fluid package parameter of column,
I would be thankful if anyone could help.
I have attached some photos.thanks
#2 Nikolay_
Nikolay_
  • 169 posts
Posted 16 July 2018 - 01:50 AM   Best Answer
To change property package try "Fluid Package Manager". It's located in the Home directory of Simulation environment (upper left corner) under the Adjust Manager.
Nikolai
#3 JABC
JABC
  • 3 posts
Posted 16 July 2018 - 04:39 AM
Nikolai
Hello Nikolai
Thank you for your useful help :)
