Hello everyone. I have a horizontal storage tank carrying high level liquid waste which produces a certain amount of constant heat due to decay. The liquid waste occupies 80% of the total volume and needs to be maintained at 50 degree©. I want to design a cooling coil whose inlet and outlet water temperatures are known. The tank dimensions, dirt factor and pipe diameter is known. How do I calculate the length of piping required and transient heat analysis when cooling water is cut off and is resumed.
Piping In Storage Tank
Started by partik1712, Jul 17 2018 06:05 AM
heat transfer pipes storage tank piping system
Posted 17 July 2018 - 06:05 AM
Posted 20 July 2018 - 10:04 AM
The heat transfer when water is flowing is easy. You need to calculate the heat transfer coefficients on either side (hi and ho) in order to get a U value. You will also need to assume the fouling factors. Then it is a simple (Q = UA∆T) calculation to get surface area. Any heat transfer textbook lays this out.
The transient case is more difficult. You could do this stepwise in a spreadsheet or MathCAD, but it becomes very involved. An FEA/CFD model would be more accurate.
10.000 M3 Tank Cost EstimationStarted by Guest_stelu85_* , 01 Jan 2026 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
Foam System Criteria For Hc Condensate Storage TanksStarted by Guest_Haideri_* , 28 Oct 2025 |
Atmospheric Tank Vent SizingStarted by Guest_kmic_* , 30 Sep 2025 |
