Arbor Type Of Fired Heater
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 12 August 2018 - 02:49 AM
Hi All,
I have 5 fired heater with all radiant sections in one firebox and a common convection section for all five fired heaters. They have mentioned it is as Arbour type of fired heater .
Can you let me know what is that ? What is so special about this type of fired heater ?
chetan Chavan
#2 PingPong
PingPong
  • 1,466 posts
Posted 12 August 2018 - 07:04 AM
The name Arbor refers to the shape of the radiant coils: many parallel inverted U-tubes
This concept is used for large gas or vapor flowrates where low pressure drop is required.
Therefor they are used in for example catalytic reformer heaters.
A common convection bank for multiple heaters can be used when flue gas temperatures from radiant cells are not too far apart, no matter what type of radiant coils are used.
#3 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 12 August 2018 - 08:50 AM
But in case of CCR heaters, why this arrangement is preferred ? nstead of having seprate radiant sections , they went for common radiant firebox and common convection box
#4 PingPong
PingPong
  • 1,466 posts
Posted 12 August 2018 - 11:58 AM
Without a sketch I am not sure what you mean by common radiant firebox.
A firebox with separation walls between the different sets of radiant coils and associated burners?
Such arrangement leads to a lower investment cost than five separate heaters.
