Does anyone know if there is a API or industry standard requirement for always having a shut down valve in the outlet of a surge tank with a pump downstream. Thanks
Posted 21 August 2018 - 10:06 AM
Posted 21 August 2018 - 11:47 AM
I recall that API has a recommendation to provide a remote operated valve between the tank and the pump. It depends on the tank volume whether the valve is required or not.
Posted 21 August 2018 - 12:32 PM
chemproc,
Not always required such SDV; it's really required downstream of the tanks containing great volume of flammable liquid to prevent relieving the flammable liquid through the outlet line following to the line failure due to any reason...
Posted 21 August 2018 - 02:23 PM
Thanks Fallah, do you know of any industry standard such as API or other codes that speaks to this issue? Thanks
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
10.000 M3 Tank Cost EstimationStarted by Guest_stelu85_* , 01 Jan 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Equal Load Sharing And Anti-Surge ControlStarted by Guest_panoska_* , 02 Nov 2025 |
