Sulfur In Vdu Overhead Stream (Off Gas)
Posted 30 August 2018 - 03:37 AM
Posted 30 August 2018 - 04:21 AM
I've performed several process designs for systems to remove H2S from the VDU overhead gases and I'll try to provide comments and answers on the base of this experience...
1) my company started to provide this design during the '90s, when the enviromental regulations constrained the contents of SOX of flue gases at very low levels. before that time the VDU off gases were simply burnt in dedicated low pressure burners, usually placed in the VDU heaters.
2) so, the scope of the amine washing is the reduction of the S content in the gases before the combustion, the presence of R-SH is negligible, up to levels that don't violate the S specification in the fuel gas. this happened in 100% of the cases I've examined in my professional life.
3) the composition shown by a process simulation is not useful for the design: it has to be measured by a lab analysis.
4) VDU off gases contain O2 and so the amine utilized for the washing is subject to degradation and, preferably, it is segregated from the other amine systems of the refinery.
good luck!
Posted 30 August 2018 - 08:19 PM
Dear
Thanks for your support. it is very helpful to understand VDU design.
The mercaptan concentration of off gas is around 400 ppm ~ 1200 ppm mol.
Is it negligible parameter on VDU operation?
The main fuel source of VDU Heater is fuel gas. So, the sulfur concentration of the mixed fuel source ( Fuel gas + off gas ) is lower than regulation.
But, i want to know the normal ratio of H2S and Mercaptan at off gas or how much mercaptan concentration is acceptable/negligible at off gas based on experience.
Missing Data For Stream ComponentsStarted by Guest_Desmith475_* , 07 Aug 2025 |
How To Remove The Condensate In A Wet Gas StreamStarted by Guest_ksagarzazu_* , 25 Feb 2025 |
Condenser Inlet Stream TemperatureStarted by Guest_Sampath123_* , 06 Jul 2024 |
Hysys Stream WorksheetStarted by Guest_nasim304_* , 22 May 2024 |
How Calculate Amount Of Water For A Water Saturated Hydrocarbon StreamStarted by Guest_AnbIran_* , 04 Oct 2023 |
