Dear all,
Could you please suggest books where I can find interfacial tension values of NaOH solution/LPG, MDEA solution/LPG, MEA solution/LPG?
Thank you
Kind regards,
Nikolai
Posted 30 September 2018 - 09:09 PM
Dear all,
Thank you
Kind regards,
Nikolai
Posted 02 October 2018 - 11:31 PM
Value from one of my project
40°C 40%MDEA+LPG (propane + butane) 47.5 dyne/cm
I am not sure this value should be trusted.
Edited by shvet1, 03 October 2018 - 05:21 AM.
Posted 03 October 2018 - 06:55 PM
Hi, thank you.
Just in case: 40 °С 20% NaOH + FCC LPG 15 dyne/cm. The source unfortunately is also unknown.
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Cstr Reactor. Where Did These Values Come From?Started by Guest_chemtoli_* , 11 Apr 2023 |
Vba Values From MaterialstreamStarted by Guest_Milnesium_* , 10 Jun 2021 |
Calculating K ValuesStarted by Guest_shahad_* , 07 Apr 2021 |
How Do I Calculate Equilibrium Ratios (K Values) For The Isothermal PtStarted by Guest_Ahmad Abbasi_* , 10 Jul 2019 |
