Hi dear members
I have a ESD valve that is intended for that bypass without parallel ESDV.
this ESDV located at the manifold of unit.
designer profess that the bypass is prepared to fill the unit at startup.
i need a document such a standard or recommended practice to proof that ESDV should not have bypass line without parallel valve or MOV valve before it.
or show that Bypass is not common for ESDV.
can you help me?
