Our client is facing an issue in convergence of steady state model of refinery CCR. Stabilizer off gas is rerouted to inlet of stabilizer in off gas drum for better absorbtion. But this circuit is not working properly in steady state model in hysys. Client wanted to change reflux flow of stabilizer from 900 TPD to 1100 TPD. Whenever we do this, we are putting distillate rate anda reflux flow as spec. But column is not converging with this.please guide. Do we need to change bottom recirculation of reboiler too generate these many vapours only. How this happens in plant . generally they maintain reboiler temp with increased firing in plant.
Chetan Chavan
Refinery Ccr Stabilizer Steady State Simulation
Started by CHEMSTRONG, Nov 21 2018 10:23 PM
Naphtha StabilizerStarted by Guest_Ashokk_* , 24 Feb 2026 |
Simulation Of Natural Gas Water Dew PointStarted by Guest_guoyinyanliner_* , 03 Nov 2025 |
Static Simulation Of An Atmospheric CduStarted by Guest_tomr91_* , 10 Aug 2025 |
Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
