I have a gas with dry basis composition. I also know that is saturated in water and the inlet and outlet pressure and temperature of the gas. I need to calculate the amount of water that condensates during cooling as you can see in the Excel attached, but something is wrong because the mass balance don't match...
What is wrong? How can I do it correctly?
Thank you very much.
PD: Inflow pressure and temperature, outflow pressure and temperature and specific gas constants are my original data (green filled cells).
Edited by guillermocp89, 19 December 2018 - 07:05 PM.
