How is possible to create a rettangular pulse disturbance in hysys? For example in a stream the mass flowrate is to be specify to vary from 5 kg/h to 100 kg/h at time t0 and return to 5 kg/h at time t0+Dt. Any idea?
Thank you
Posted 11 January 2019 - 09:24 AM
Thank you
Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
