Flow Through Orifice Discharging Freely Into The Air
orifice discharge coefficient fluid flow through orifice
#1 MissK4
MissK4
  • 8 posts
Posted 14 January 2019 - 01:50 AM
Hi, I am currently doing an experiment of measuring the discharge flow rate through an orifice on the side of a tank that is discharging water freely into the air whilst the water level in the tank is kept constant. I also calculated the coefficient of discharge from the following equation; Q=Cd*a*√2gH. Initially the values I got for Cd are more than 1. How do I justify why the Cd values are more than 1 and why should it ideally be less than 1? Also, does anyone have any references from literature that I could check on the typical values for Cd for orifices discharging freely into the air? I need reliable sources that I can quote. Thank you
Edited by MissK4, 14 January 2019 - 01:54 AM.
#2 fallah
  • 5,026 posts
Posted 14 January 2019 - 02:04 AM
Crane TP 410 is a good source for your query...
#3 breizh
  • 6,937 posts
Posted 14 January 2019 - 03:29 AM
http://site.iugaza.e...xperiment-5.pdf
You should find pointers in the link above.
Good luck.
