Posted 16 January 2019 - 06:15 PM
hello, what is the applicable code to design of small diameter (3 inch) and short length (few hundred meters) piping with utility (fuel) natural gas and instrument air, in Canada? What does it depend on?
thanks for any input.
Posted 20 January 2019 - 01:10 AM
Generally these are designed to ASME B31.3 in Canada. Check your provincial regulations.
Posted 01 February 2019 - 05:17 AM
The TracPipe fuel gas piping system consists of corrugated, semi-rigid stainless steel tubing with brass mechanical attachment fittings terminating in male pipe fittings for easy attachment to traditional black iron pipe systems and direct connections to gas appliances.
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , Today, 01:43 AM |
