Simulation Of Gtl Plant Using Hysys
Posted 20 January 2019 - 03:14 AM
Thank you.
Posted 20 January 2019 - 10:27 AM
So, is this facility finally operating? Optimization can mean lots of things. If you already have a ChE degree, use what you have learned. And try different ways. Maybe Chevron engineers can help you.
Posted 26 January 2019 - 12:12 PM
Posted 26 January 2019 - 12:15 PM
Posted 26 January 2019 - 07:13 PM
So, are you now working at the Escravos GTL facility? The process modules for all the syngas processes are already present. I don't know that you can actually optimize with the built-in equilibrium model. And there is little to do except maybe vary the oxygen ratio and the reformer outlet temperature. Optimize can mean many things.
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
