I am using Hysys 9, as you know there is a data bank for known petroleum assays around the world .
My problem is, that I can’t find a way to install oil and blend from those predifined assays in data bank .
Would be glad if anyone could help me .
How To Make Streams From Petroleum Assay In Hysys
Started by Gmadhi@orioncnsl.com, Jan 21 2019 03:43 AM
Crude Assay Pure Component AdditionStarted by Guest_darknight1991_* , 17 Jan 2026 |
How To Determine The Pressure At A Mixing Node For Two Streams With DiStarted by Guest_samin_chemeng_* , 02 Oct 2025 |
