Organic Sulfur Compound Absorption
Started by HailToPitt, Mar 20 2019 12:38 PM
Posted 20 March 2019 - 12:38 PM
Wanted to see if anyone had some insight into this. Suppose I have a fuel gas stream that needs cleaned of organic sulfur compounds, primarily CS2 (500-700 ppm) and COS (150-200 ppm) and want to get it as clean as possible for consumption. What industrially viable process could in use to achieve this?
The most promising results I've found are the use of a Hoffman-type polymer (though I'm not sure if stripping the gas back off afterward is easily done) and circulating mineral oil (seen in a 1966 patent).
Thanks!
Thanks!
Posted 23 March 2019 - 12:05 AM
Hello Hail,
I suggest you consider your gas to be known as a sour gas due to the sulphur compounds. You could read up on gas sweetening processes for desulphurisation. There are many processes / methods, best one(s) may depend on concentrations at inlet and outlet, and the scale of operation.
Dazzler
Edited by Dazzler, 23 March 2019 - 12:06 AM.
Posted 28 March 2019 - 08:29 AM
Gas separation membranes can be a possibility as well.
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Synthetic Organic PigmentStarted by Guest_Rahimzadeh_* , 23 Sep 2024 |
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
Solvent Carryover Emissions In Absorption ProcessStarted by Guest_TeeEng_* , 24 Oct 2023 |
Sulfur Storage SiloStarted by Guest_Muhammad farhan_* , 30 Mar 2018 |
