Evaporators On Hysys
simulation hysys evaporators aspen nitric acid
#1 Pintinho375
Pintinho375
  • 2 posts
Posted 01 April 2019 - 10:55 AM
Hello!
I'm doing my Master's thesis on the production of nitric acid.
I came across some evaporators i need to simulate on Hysys but there isn't any in the software (10.1).
I was thinking on adding an heat exchanger and then a separator. But i'm not sure if this is the best way.
How would you do it?
Thank you
#2 Bobby Strain
Posted 01 April 2019 - 06:29 PM
So, what is the service for this evaporator?
#3 Pintinho375
Pintinho375
  • 2 posts
Posted 03 April 2019 - 03:59 PM
Thank you for the reply Bobby
Is is used for separating the water from the ammonia as it heats it.
#4 Bobby Strain
Posted 03 April 2019 - 04:53 PM
The process usually uses anhydrous ammonia. If there is water in the ammonia, it will dilute the acid product. If you don't have anhydrous ammonia, you will need a fractionator, not a simple evaporator.
#5 Tanhieungo
Tanhieungo
  • 13 posts
Posted 02 May 2019 - 06:07 PM
if you use hysys dynamic ,you should use tube bundle function to simulate ketlle or evapor (chiller )
if you use steady state hysys .you should use heat exchanger and seperator
