Plant Start-Up With Recycle
#1 cheisfun
cheisfun
Posted 10 April 2019 - 08:55 AM
Hi all,
I would like to know if I were to have a recycle stream of a solvent in my process, how do I cost my initial starting solvent cost required during the start-up of the plant?
Because currently, I have simulated a recycle loop where most of the solvent is recycled while a small makeup stream is added. As the recycle flow rate is in tons/h I am unsure how to determine the initial solvent amount that I require during start up. I am thinking that I need to calculate the total residence time of all equipment in the recycle loop and multiply it by the solvent recycle flow rate, but I am not entirely sure if that is correct.
I hope you could help to clarify my doubts.
Thanks.
  • 6,934 posts
Posted 10 April 2019 - 10:30 AM
Hi cheisfun,
Solvent (initial charge) should be part of the Capex. Regarding the quantity , you need to calculate the volume of all the piping and equipment on your recycling loop where pass the solvent   . All the information should be available from the data sheet of equipment and isometric of the piping.
Edited by breizh, 10 April 2019 - 10:31 AM.
#3 cheisfun
cheisfun
Posted 10 April 2019 - 09:21 PM
Thank you so much for your reply.
