In Aspen Hysys dynamics simulation, the minimum closing/opening time of a valve (or the actuator speed) is minimum 20 seconds.
Why I am not able to make it less than 20 s?
Thank you.
Posted 13 April 2019 - 02:53 PM
Thank you.
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , Yesterday, 04:37 PM |
