In furnaces, very high pressure steam is produced from waste heat. This waste heat is actually is recovered from the convection section. By producing this very high pressure steam, then this steam is used in the cracked gas turbines and then there is steam extraction to lower steam levels, such as MP, LP, etc. MP steam for example is used from the turbines, which drive the compressors in the refrigeration cycle. The refrigeration cycle is used from different condensers in distillation columns. Consequently, why we need to reduce the energy of these columns? If we reduce the energy of these columns, that means condenser or reboiler duties reduction. That means steam reduction, which means less recovery of waste heat? Why to reduce the use of the waste of heat, since it is available?
Thank you in advance!
