I am trying to better understand the safety risks of a 316L stainless steel storage tank with a dilute (<3 wt%) solution of Phosphoric acid at about 100F. Some quick searching and conversations with tank vendors indicated that 316L is the metallic MOC which will be least corroded by the phosphoric acid, but basic chemistry tells me that reactions with iron and nickel will still happen, resulting in production of hydrogen gas. I would like to know if there will be enough hydrogen production that the room/system would have to be designed per NFPA 2 code, but I can't seem to find any sources that will tell me reaction rates for these reactions. Wondering if there are any seasoned engineers out there who have some guidance.
Phosphoric Acid Corrosion Of 316L Ss Tank
Started by Rminor, May 13 2019 02:16 PM
moc phosphoric acid hydrogen gas
No replies to this topic
Posted 13 May 2019 - 02:16 PM
10.000 M3 Tank Cost EstimationStarted by Guest_stelu85_* , 01 Jan 2026 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Atmospheric Tank Vent SizingStarted by Guest_kmic_* , 30 Sep 2025 |
Storage Tank Relief LoadStarted by Guest_hum464_* , 10 Sep 2025 |
Refrigerated Storage Tank Vaccum Breaker CapacityStarted by Guest_Lyne_* , 13 Sep 2025 |
