Gents,
I have a question I encountered while sizing a PSV. I have separator with class rating #900. I set the pressure to be the max. pressure class #900 can withstand at this temperature. In case of fire, I have to add 21% allowable over-pressure according to the API 521, which will produce pressure above that of rating #900 can withstand. To cut a long story short, my question is how it is acceptable to set the PSV pressure to be the MAWP because when adding the allowable over pressure (10% for blocked outlet, 21% for fire), the equipment's flanges will be exposed to pressure higher than they can withstand.
Thanks in advance.
Mohamed M. Abdelhameed
Psv Sizing
Started by Mohamed94, May 16 2019 07:19 AM
Posted 16 May 2019 - 07:19 AM
Posted 16 May 2019 - 12:41 PM Best Answer
Mohamed:
Perhaps the attached document found at our thread, https://www.cheresou...ation-pressure/
may be of help in resolving your application of the MAWP with regards to the appropriate PSV to protect your system (not just the separator).
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Separator SizingStarted by Guest_HOTTEST_* , 12 Mar 2026 |
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
