Hi All..
We are facing high chloride value in our amine system Please share your ideas how we can nip the problem. chlorides are on the rising trend.
Posted 16 May 2019 - 12:39 PM
Hi All..
Posted 22 October 2019 - 02:05 AM
If the system has a reclaimer or something, then you might solve the chlorine accumulation by increasing the blow down rate.
Posted 14 November 2019 - 12:37 AM
Hi imrannawaz,
First of all, where this increase of chloride content come? is it coming from the gas feed which means it is unavoidable or from something else.
Further it would be better to give a brief explanation about the type of Amine system that you are using, simple PFD would help a lot.
We are all here engineer after all, not fortune teller. We can try to help what with giving some solutions from our past experience but we cannot simply guessing as our credibility also in question. especially considering that this is an open forum when people can freely judge others.
Posted 04 April 2021 - 06:13 AM
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Negative Pressure Discharge / Negative At High PointStarted by Guest_felderosfelder101021_* , 05 Jul 2025 |
Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
High Stack Temperature In Ccr HeatersStarted by Guest_viba0124_* , 30 Nov 2024 |
