Amine Stripper Column Design
amine stripper stripper desorption design amine regenerator acid gas
#1 Skylar
Skylar
  • 5 posts
Posted 20 May 2019 - 02:55 PM
Hello everyone,
I am currently researching more on the design of a amine stripping column but have met some roadblocks. To my best understanding, a stripping column is basically the opposite of an absorption column. However, there are very limited literature and articles on a stripping column design. Therefore, I would like to use this platform to clarify some of my findings through the limited resources. I will be focusing on the design of a multi component stripping column mainly on the removal of CO2 and H2S
1. Mass Balance for Stripper Column
Since stripper is the opposite of absorption, is it correct to say that the mass balance of stripper column will the similar to the absorption. However, I am unsure of the formulas used for a multi component stripper column mass balance.
2. To determine the number of theoretical trays in the stripper column.
I've read through numerous articles and realized that the number of trays in the column usually depends on industrial knowledge. However, is it possible to obtain the number of theoretical trays through the McCabe Thiele method?
3.Sizing of a stripper column
Are there any industrial guidelines on the sizing of a stripper column.
Thank in advance
Best Regards,
Skylar
Edited by Skylar, 20 May 2019 - 02:57 PM.
Posted 20 May 2019 - 03:21 PM
Skylar:
You state you “would like to use this platform to clarify some of my findings”.  O.K., so what are those findings??  Please be specific.
You state that you are “unsure of the formulas used for a multi component stripper column mass balance”.  What formulas are you referring to?  Where did you obtain them?
The height of an amine stripper column is determined empirically for practical purposes.  I’ve used the McCabe-Thiele method to calculate it in the past and found that the number of stages is very small - around 2 or 3 theoretical stages.
I don’t know what you mean by “industrial guidelines”.  I just told you the design of an amine stripper is determined empirically for practical purposes.  If you would like to discuss those practical purposes, than state so.
#3 breizh
  • 6,939 posts
Posted 21 May 2019 - 06:37 AM
hi ,
Consider this literature to support your work .
#4 breizh
  • 6,939 posts
Posted 22 May 2019 - 06:34 AM
In addition to my previous answer , you may consider the link attached :
http://www.gas-compr...or-amine-system
Another document to consult is GPSA engineering data book.
