Enthalpy Of Vaporization Below Boiling Point
9 replies to this topic
#1 cheminst
cheminst
  • 33 posts
Posted 16 June 2019 - 08:58 AM
Can anyone please explain how to calculate the enthalpy change when water is evaporating below the boiling point? e.g. 50 Celsius at 1 atm.
Any reference book or webpage link?
#2 PingPong
PingPong
  • 1,474 posts
Posted 16 June 2019 - 09:10 AM
Use a Steam Table.
#3 cheminst
cheminst
  • 33 posts
Posted 16 June 2019 - 09:39 AM
Use a Steam Table.
Actually in a steam table there are only data for saturated steam and superheated steam. The data I want are the enthalpy change of vaporization of water at 1 atm below boiling point (100 Celsius) e.g 30, 40, 50, 60 Celsius.  This is neither saturated steam nor superheated steam.
#4 PingPong
PingPong
  • 1,474 posts
Posted 16 June 2019 - 11:06 AM
At low pressure all gases behave like (nearly) ideal gases and therefor impact of pressure on enthalpy is negligible.
#5 PhilippM
PhilippM
  • 98 posts
Posted 16 June 2019 - 11:12 AM
What else is the steam supposed to be?
#6 cheminst
cheminst
  • 33 posts
Posted 16 June 2019 - 11:14 AM
Thanks for the clarification.
#7 cheminst
cheminst
  • 33 posts
Posted 16 June 2019 - 11:15 AM
Actually I meant the steam for which only the data are given in steam tables
#8 PingPong
PingPong
  • 1,474 posts
Posted 16 June 2019 - 11:50 AM
At 50 oC water has a vapor pressure of 0.123 bar, so saturated steam at 50 oC has a partial pressure of 0.123 bar.
In air (or whatever gas) at 1 atm the steam partial pressure at 50 oC is only 0.123 bar and the air partial pressure is 0.89 bar.
The enthalpy of pure steam at 50 oC and 0.123 bar total pressure will be practically the same as the enthalpy of steam at 50 oC in air at a total pressure of 1 atm.
#9 breizh
  • 6,939 posts
Posted 17 June 2019 - 12:01 AM
https://www4.eere.en..._tool/propSteam
Let you try he calculator above , just pay attention to the inputs  (F,PSI g) .
good luck
#10 cheminst
cheminst
  • 33 posts
Posted 17 June 2019 - 12:05 AM   Best Answer
Found the data
good luck
Thanks for the link. I found NIST data through this link.
https://webbook.nist...Pa*s&STUnit=N/m
