I've recently been asked the following question from an industrial professional, however, I do not have any background knowledge in gas plants, and I would like to receive some guidance on how to approach this question.
The question is as follows: In a traditional gas plant set up, the Inlet Gas is first routed to an inlet separator. The Hydrocarbon Liquids from the inlet separator are “stabilized” in a Stabilizer. At times recycling the stabilizer overheads gas back to the inlet of the Inlet Separator is not advisable, can you explain why this would be the case?
Thank you!
