Hello everyone
i am working in oil production company, recently we have a problem with one of our fields due to increasing water cut in wells. we have large pipeline 12'' from wells to gas production facility can handle more than 50000 BFPD(oil+water) with associated gas without any back pressure on wells but we have a limitation on the facility it self it can handle only 25000 BFPD. in the same time we have an oil facility in the neighborhood have the capacity to handle the excess fluid from the pipeline but it not have compressors to produce gas. So if we divert the pipeline we will flare the gas about 10 MMSCFD and this is a huge amount to flare it (from environment and production view) not from facility flaring capacity. another option is to separate the liquid before entering gas facility and divert it to oil facility and divert gas to gas facility but it needs a large separator can handle 50000 BFPD and this is cannot easily find in market. one of staff recommended what called dip-leg to separate the liquid. it is simply a large pipeline 18'' or 24'' to decrease flow velocity then collect 25000 bfpd from pipe bottom and remaining gas and oil go to gas facility. noting that we don't need good separation we need only to make selectivity major of oil stream go to oil plant and major of gas stream go to gas plant.
I attached the proposal pic for review. I want to know if any one see this configuration before? and can from your opinion separate liquid? and what are the concerns of using this technique?
Dip-Leg Configuration
Started by mido, Jul 01 2019 04:33 AM
Posted 01 July 2019 - 04:33 AM
Posted 08 July 2019 - 11:51 AM
is there any one watch this configuration or have concerns about it?
![]() Steam Turbine Flow Configuration EnquiryStarted by Guest_Said Salim_* , 09 Mar 2022 |
![]() Series And Parallel Configuration Of ShellStarted by Guest_274@P6_* , 22 Jan 2020 |
![]() Control ConfigurationStarted by Guest_274@P6_* , 11 Dec 2019 |
![]() Deluge System ConfigurationStarted by Guest_Abdelilah_* , 08 Oct 2019 |
![]() Crude Oil Column Simulation Hysys - ConfigurationStarted by Guest_Miss_Jasmine_* , 01 Oct 2018 |
