How Do I Calculate Equilibrium Ratios (K Values) For The Isothermal Pt
vle phase equilibria rachford rice k values
#1 Ahmad Abbasi
Ahmad Abbasi
  • 5 posts
Posted 10 July 2019 - 02:51 AM
Hi everyone
For calculating the vapour fraction and phase compositions of a hydrocarbon mixture at given Pressure, Temperature and overall compositions, the rachford-rice equation needs to be solved.
Because of the absence of phase composition (x-y) information in the beginning, we need starting values for the equilibrium K Ratios, (since the K values are composition dependent) for initialising the rachford rice solution procedure. Upon subsequent computation of phase composition, K values are reevaluated using the new information and the procedure is repeated until convergence.
I know about the raoult's approximation for K values (vapor pressure/System pressure) and the wilson correlation.
But they don't seem to be very helpful, because it often happens that for the initial estimated values of the K ratios, no feasible solution of the vapour fraction exists, which should ideally be between 0 and 1.
So I would like for any leads which would help me set good initial values for K ratios to ensure robust evaluation of the vapour fraction
  • 6,939 posts
Posted 10 July 2019 - 03:19 AM   Best Answer
Let you consider the excel sheet attached where you can find several options to support your work .
hope this is helping you and others .
#3 Ahmad Abbasi
Ahmad Abbasi
  • 5 posts
Posted 10 July 2019 - 11:53 AM
Dear Breizh
I had a long and detailed look at your spreadsheet and compared it to what DWSIM outputs. Then I compared it to my code. It's a pretty good spreadsheet, only thing is it will not incorporate the new phase compositions to evaluate the new K values.
Anyway, it does what I wanted it to: give me a good way to initialise the rachford rice method and do one iteration with a reasonable output of vapour fraction (ie 0<= V<=1).
Thanks. It helped me validate my code.
#4 HARAB
HARAB
Posted 02 February 2021 - 05:48 AM
I would like to know about convergence pressure Pk ..assume that we have reservoir fluid composition (Pres, Tres, Zi are  Known) , and we would like to estimate Pb pressure (unknown), by using Rachford Rice equation(RR eq.) when we want to calculate the K values  we need the value of Pk, Is there any equation to calculate it direct with high accuracy  ,any example done by spreadsheet !!
​Kind regards
#5 breizh
  • 6,939 posts
Posted 02 February 2021 - 06:51 AM
To get a meaningful answer I encourage you to define the variables included in your post ( Pb , Pk) .
#6 SilverShaded
SilverShaded
  • 237 posts
Posted 04 February 2021 - 05:34 AM
​Kind regards
Typically you use rachford rice to calcuate the amount of vaporisation at a known temperature and pressure, you iterate around until the K values converge. (if your doing it rigorously).
To find the Pressue at a specific level of vaporisation you have another outer convergence loop, whereby you adjust P untl you get the bubble point/dew point or whatever other criteria your trying to meet.
Edited by SilverShaded, 04 February 2021 - 05:34 AM.
#7 breizh
  • 6,939 posts
Posted 04 February 2021 - 06:51 AM
You may consider the excel sheet attached , in particular the methodology used
You may also consider this resource  from internet :
https://www.questcon...oftware/canary/
