Foaming In Cooling Water
#1 Lukman
Lukman
  • 6 posts
Posted 29 September 2006 - 12:37 AM
I have found foaming in cooling water system since last year. We did not change any cooling water treatment chemical. However, to decrease foaming accumulation in cooling water system we just revome it mechanically. We also have consulted with the chemical supplier but the problem still exist although we have followed their recommendation, including charge a new cooling water treatment chemical.
Please help me, why does foaming appeared in cooling water? And how to remove it chemically?
Thanks a lot for your advises.
Lukman
Hydrogen Peroxide Info
#2 Natural FAL
Natural FAL
  • 28 posts
Posted 30 September 2006 - 11:37 AM
QUOTE (Lukman @ Sep 29 2006, 01:37 PM) <{POST_SNAPBACK}>
Lukman
Hi Lukman,
At first, I would like to know what product you are producing in the plant? The cooling water system is in the closed loop circulation normally go the heat exchanges. I suspect your product have gone into your cooling water system due to tube leaks in the heat exchanges. I believe you have sent a cooling water sample to check on the content. If any soapy, acidic material found in your water. Yes, it will form foaming issue. Hope it helps.
Natural FAL
#3 Zauberberg
Zauberberg
  • 2,728 posts
Posted 30 September 2006 - 11:48 AM
Hello Lukman,
There was a similar topic recently, take a look at:
http://www.cheresour...?showtopic=2679
