Inert Atmosphere Standards
#1 muthukmaar
muthukmaar
  • 53 posts
Posted 23 July 2019 - 06:18 AM
What are the safety standards that are to be followed while unloading a pyroporic catalyst which is not reduced under inert atmosphere
  • 1,635 posts
Posted 23 July 2019 - 11:38 AM
Start with the catalyst manufacturer's guidelines and improve upon them for your specific situation. Can you unload the catalyst wet?
#3 breizh
  • 6,939 posts
Posted 23 July 2019 - 06:48 PM
You need to be extremely cautious with this type of operation .I'm aware of fatality ( hydrogenation reactor burst) because the SOP was not understood or followed .
In any case you need knowledgeable people within your organization to support you ,approve the SOP and follow the operation  .
A description of your process will be helpful .
Good luck .
Edited by breizh, 24 July 2019 - 03:48 AM.
#4 muthukmaar
muthukmaar
  • 53 posts
Posted 25 July 2019 - 03:19 AM
The process is Ammonia production in which the Low Temperature Shift Conversion catalyst Copper in its reduced state is kept under    positive nitrogen pressure by continuous supply. Personnel wearing appropriate PPEs and having adequate help are only used. Also , to be noted is that the personnel are experts in the same field.My question is that whether there are any established standards to be followed such as OSHA or OISD.
#5 breizh
  • 6,939 posts
Posted 25 July 2019 - 04:23 AM
Attached 2 documents from Internet .
Hope this is going to help you .
Good Luck
Edited by breizh, 25 July 2019 - 05:51 AM.
#6 muthukmaar
muthukmaar
  • 53 posts
Posted 29 July 2019 - 01:52 AM
Thank you Sir
