Pressure Vessel Design Temperature And Design Pressure
pressure vessel design
7 replies to this topic
#1 Abdelilah
Abdelilah
  • 25 posts
Posted 06 August 2019 - 12:55 AM
Dear all,
Please, need some clarification from you guys.
Our contractor is design a Mercury bed inlet KO with two design pressure and two design temperature. This KO drum is installed at the downstream of compressor air coolers.
For information:
OP = 71 barg @ 62°C.
PSV set @ 78 barg.
He considered two scenarios for that :
Scenario 1 :
Operating pressure (71 barg) with failure of the air cooler (120°C). Design condition : 77 barg @ 120°C
Scenario 2 :
Operating pressure (78 barg) with blocked outlet @ (62°C). Design condition : 78 barg @ 100°C
However, as per my understanding, pressure vessel shall be designed with coincidental conditions. in our cas, it shall be (78 barg @ 120°). But the contractor insist that this is not correct since blocked outlet+air cooler failure is not envisaged as double jeopardy.
So, please can some explain which scenario shall be considered for the (datsheet, name plate,..) why and any standard that treat this subject.
Thanks in advance.
Edited by Abdelilah, 06 August 2019 - 01:21 AM.
#2 Bobby Strain
Posted 06 August 2019 - 11:21 PM
You probably have already wasted money on an oversized separator. You would have been wiser to look carefully at the size, and hence the cost. It's your money. Apply the golden rule: The client has the gold, she can make the rules.
#3 Abdelilah
Abdelilah
  • 25 posts
Posted 07 August 2019 - 04:31 AM
it would be nice if you share a technical response instead of philosophy.
#4 fallah
  • 5,026 posts
Posted 07 August 2019 - 12:19 PM
For information:
PSV set @ 78 barg.
Scenario 1 :
Scenario 2 :
The vessel you did describe has two design conditions, even though the temperature difference also pressure difference between two cases are so small to be able to affect the pressure vessel design.
Nonetheless, based on the general engineering practices, you can calculate the thickness of the shell/head of the vessel in two mentioned conditions and select the conditions of the case leading to a higher thickness as governing design pressure/temperature of the vessel.
#5 PhilippM
PhilippM
  • 98 posts
Posted 07 August 2019 - 12:29 PM
I think here in Germany it is possible to assign two different combinations of PS/TS (maximum allowable pressure/temperature as defined in the Pressure Equipment Directive). However, this is very rarely done, as it causes additional effort for the documentation.
One example would be a reactor which needs to be regenerated during a special operation mode with lower pressure but much higher temperature than in normal operation.
In this case it can be ensured that after regeneration the temperature is lowered for a sufficiently long time for all the steel to cool down so that it does not exceed the TS of the normal operation design case.
The case you are describing would normally not be dealt with this way, as you can't really make sure that scenario 2 does not occur right after scenario 1.
With the process data you've stated however I wonder why anyone would even think about this. I can't imagine that a design temperature of 120°C vs. 100°C would have any significant impact on the cost (unless the KO drum will be made of plastic).
The size of the drum will have a vastly larger impact on the cost and should therefore be scrutinized, instead of haggling about a difference of 20°C.
#6 rikakose
rikakose
  • 80 posts
Posted 09 August 2019 - 08:32 AM
There is no difference of cost between 100ºC and 120ºC.
Edited by rikakose, 09 August 2019 - 08:39 AM.
#7 Abdelilah
Abdelilah
  • 25 posts
Posted 08 October 2019 - 02:54 AM
Many thanks for your valuable replies.
The problem is not about the cost.
The contractor has made an input mistake for the design temperature (100°C instead of 120C) in the mechanical datasheet.
Therefore, the manufacturer calculated the thickness according to 100°C @ 78 barg instead of 120°C @ 78 barg and brought the metal sheets for fabrication.
When the contractor noticed the mistake to the manufacturer, it recalculate the new thickness and found that the brought sheet cannot withstand 78 barg @ 120°C.
Therefore, the contractor asked us to solve the problem by specifying two design conditions in the datasheet for the vessel. Since this vessel is located downstream of air cooler, he argue that:
Condition 1: 120°C (design temperature) can occur only during air cooler failure during normal operating pressure (69 barg).
Condition 2 : 78 barg (design pressure) can only occur during blocked outlet at operating temperature (70°C)
#8 PhilippM
PhilippM
  • 98 posts
Posted 13 October 2019 - 08:34 AM
What were the specifications that the client agreed to and that were used for the HAZOP?
The client has to decide if he wants to pay for a vessel that does not meet the specifications.
Usually you have a single MAWP and a single MAWT and not a MAWP that is only valid at a temperature below MAWT.
If I'm not mistaken having two sets of design data is possible (depending on the jurisdiction and applicable codes and standards) but causes additional costs and problems.
