Suction Strainer Of Centrifugal Pumps
Posted 09 August 2019 - 09:59 AM
I am writing to inquire about the strainers on the suction side of centrifugal pumps. My question is when they are mandated to be installed? Is there an international standard that specifies that (e.g. API)?
Posted 09 August 2019 - 10:59 AM
In my experience so far, the client has always decided if he wants a strainer or not, usually based on experience with a pump in a similar service.
Posted 09 August 2019 - 11:41 AM
My service is reduced crude from the bottom of main CDU Column. I know this service is fouling and many companies require strainers in such service (e.g. ExxonMobil). However, my client don't think it is required.
Posted 09 August 2019 - 12:58 PM
Hi Vegeta.
One question: is your client an expert in CDU operations?
My guess is: NO.
Good luck!
Posted 09 August 2019 - 02:55 PM
What is your scope for services?
Posted 09 August 2019 - 11:56 PM
I have no idea about that because my communication with them is through one to three persons only.
Bobby Strain,
It is to run hydraulics for future revamp due to capacity increase and to provide any necessary recommendations.
Posted 10 August 2019 - 01:30 AM
Hi Vegeta,
https://www.scribd.c...perating-Manual
You may find some pointers reading the document above.
Good luck.
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Centrifugal Compressor TroubleshootingStarted by Guest_sggifrance@gmail.com_* , 14 Sep 2025 |
Centrifugal Compressor RecycleStarted by Guest_Lyne_* , 19 Aug 2025 |
