Dear all,
What are the cases in which the LMTD cannot be used?
What is the zone analysis used in the exchangers?
Thank you in advance!
Posted 22 October 2019 - 01:55 AM
LMTD can not be calculated if one of end point differential temperatures is the same as the other, (LMTD = (Δt1 - Δt2)/ln (Δt1 / Δt2), ln 1 = Error)
Zone analysis should be used if significant difference or heat-duty is involved in the particular zone of a exchanger.
Stefano, Kim
Heat Exchanger Increase Of Lmtd/decrease Of UStarted by Guest_jordan1111_* , 29 Sep 2021 |
How To Calculate Lmtd With 2 Different Inlet Temperature (Mixer)Started by Guest_dhimas.ad_* , 21 Dec 2020 |
Lmtd For Steam Heated ExchangersStarted by Guest_A.BHANU_* , 02 Mar 2017 |
Lmtd Vs. AmtdStarted by Guest_ashton46_* , 14 Apr 2016 |
Lmtd Of Multi-Stream ExchangerStarted by Guest_Bodhisatya_* , 28 Jan 2016 |
