Hi All
I am working on a study. I have Double shaft Gas Turbine compressor datasheet mentioning inlet air and fuel gas requirement on rated flow. The datasheet is quite old and compressor curves or not available.
I want to calculate the exhaust gas flow from turbine during 70% compressor load. Is there any tool or spreadsheet by which I can estimate the exhaust flow at 70% compressor load.
Adil
